qhad
Mar 31, 2021Aspirant
Weird TX/RX -rate vs link status and poor speed vs link strength
Hi. Why I'm getting really poor TX-rate and why TX-rate is sigfinicately lower than RX-rate? - Daisy chain technology activated on SRR60 - RBS50Y is connectd to SRR60 (with link status -79dBM) ...
DaneA
Apr 05, 2021NETGEAR Employee Retired
qhad,
Thank you for your response. Based from the details you have provided, I suggest you to open a support ticket with the NETGEAR Support Team here at anytime for further investigation. Kindly state your concern as well as you may include the link to this community thread.
DaneA
NETGEAR Community Team
qhad
Apr 16, 2021Aspirant
Hi - I found one very nasty problem with one of my two RBS50Ys - at least this unit seems to be water tight at bottom... I need to check how your warranty works and is there any left. At least this kind of unit which is expensive and sold as part of business network should work more than two months. Sadly this particular unit stayed almost two years as unused after I bought it (bought it as spare/replacement unit) and I started using it using it only two months ago - only because I started to solve my problem weird TX vs RX vs link status strengt! My other older unit has been on this exact same location before this moistured one about two years without any problems within water tightness.
