Simpsonic
Apr 16, 2026Follower
Armor failed to subscribe
Has anyone figured out a solution to this issue? Please help. I want to be protected, and Netgear NEEDS to fix this issue in an update. If the trial ends, it should be simple. The link should take...
Apr 16, 2026Guru - Experienced User
You'll need to contact NG support for help and information regarding Armor subscriptions. All that is beyond forum help:
Armor Help and Information FAQ | NETGEAR Communities
