TwoDogs22's avatar
TwoDogs22
Armor missing from web interface
I pressed the power button on the router as I was having streaming tv issues and it factory reset. after rebuilding it I've lost my Armor option in the web interface. It's visible in the ios app though. How do I get it back please
Thanks
  • OK, yeah so you'll need to download the Nighthawk App from the app store.
  • Can you just confirm what router you're using please and the firmware version you're on?
    • TwoDogs22's avatar
      TwoDogs22
      Netgear Nighthawk Xr1000
      Firmware version V1.0.0.58
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        You can't really change any settings on the interface for Armor, it's all done on the app. You should see a shield icon top right of the interface though, do you see that? If not can you provide a full screen picture please?
