LawrenceNg's avatar
LawrenceNg
Armor plan not avail on RBR50
I cannot subscribe to a new armor subscription for my older RBR pls help. Getting DOS and man to man flooDs.
  • plemans's avatar
    what firmware version are you on?
    It should support armor.
    Which products support NETGEAR Armor? | Answer | NETGEAR Support
    To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process.
    Click on: My Support---->Contact Support---->Get help with my subscription service
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello LawrenceNg,
        I understand that you are having difficulties subscribing to a new armor subscription.
        plemans is correct, your RBR50 supports NETGEAR Armor.
        What is happening when you try to subscribe to a new subscription?
        Best,
        Kevin
        Community Team
