DavidTreg's avatar
DavidTreg
Follower
Dec 12, 2020
Armor renewal say “this plan not available”
Hi my Armor subscription has expired. When I go into the Orbi app, I see “Security expired” so I clicked on it. I get a message saying checking NETGEAR armor status and then it comes up with the image below that says “This plan is not available”. I have had the router for just over a year and would like to buy an extension but there doesn’t seem to be an option. Thanks
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello DavidTreg,
    May you reinstall the Orbi app and power cycle your router and check to see if you're able to subscribe to Armor. Please let me know if your issue persists.
    Christian
    • Manxviking's avatar
      Manxviking
      Tutor
      I have the same issue. I have reinstalled the app and rebooted the router but the problem still exists.
        Christian_R
        Hello Manxviking,
        May you send me a private message with your email address and router serial number for us to check further.
        Christian
