MartinIan's avatar
Aug 12, 2026
Armor running on Snapdragon
Can anyone tell me if the issue with Armor on a ARM Snapdragon system is fixed. I have just updated my Laptop and its running Snapdragon, so before I spin my wheels installing Armor it'd be great know whether it'll work .
Thanks
    There was a conversation in 2024-2025 about Armor not installing on ARM systems, whereas Bitdefender itself worked correctly:
    Re: NetGear Armor for Windows 11 | NETGEAR Communities
    The only "issue" seemed to be that it simply did not install.  Why not give it a try?
    (back up the laptop first, of course.)
  • FURRYe38's avatar
    May not be a common platform for most users. Something to try on your own as see.
    Might contact Bit Defender support to ask about support running on that platform.
    Hope someone with that platform can comment, but you may not get any feedback.
