Ridenslide
Feb 07, 2022Initiate
Armor Says Expired But Has Active Dates Listed
Armor continues to fail to protect us. It worked fine until we renewed and now all of a sudden it constantly says it is expired even though somehow it updated the dates of the subscription to reflect ...
- Feb 07, 2022Issues are corrected and everything seems to be working well again. Thanks.
michaelkenward
Feb 07, 2022Guru - Experienced User
You might do better here:
What is the NETGEAR Armor Bitdefender Total Security feature? | Answer | NETGEAR Support
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. When it comes to your RBR50, your question is about an Orbi device which is very different technology from the Nighthawk WiFi Routers covered here.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
