Rmalibu
May 25, 2022Star
armor security and need to add the bit defender
On my orbi 853 had the trial armor security and when tap the security panel it lets me know that bitdefender can be added to 11 devices on my system and if i click on install i am asked to get the bitdefender app and go from there to add devices and they say at no cost My question is i thought that having the armor security that the router and all devices connected to it both wired and wireless were supposedly protected by armor True? if not why do they say armor protects " all your devices connected" and if not is bitdefender recommended and if so why does it only say that only 11 devices can be installed if i have more than 11 devices connected
Its more about different suites/levels of protection.
yes, armor is protecting your devices on the network. scanning them for their own vulnerabilities/etc. But if you download a program onto your device willfully and its a virus/malware, then you'd need something on that device to scan/know it.
Kind of like how companies used to sell malware protection, web browser protection, antivirus protection, etc.
So Bitdefender then via their app get installed on those devices and acts as virus malware protection? Much like say avast or similar products? So if you have something like that say on a computer or iPad why would you need Bitdefender
You'd have to check with the specifics of the program you install on your device for what it actually protects against.
