willb_1968
Dec 19, 2025Aspirant
"Armor" suddenly turned itself on?
I've had a Orbi 370 system for a few weeks now, everything has been working fine, suddenly a site I regularly access is now "blocked" because "Armor" got switched on somehow and decided it was danger...
Dec 20, 2025Guru - Experienced User
Its pretty easy to disable from the app. Install the app, disable it, and then just delete the app.
I don't like when stuff is "auto-enabled" either and it should be able to be disabled from the GUI.
