edjenn1998
Sep 07, 2020Aspirant
Armor Will not activate
Armor will Not activate. I gave up on phone support after waiting for too long to get a person to help. I used the chat support and I was told to basically unplug the router for 2 min and restart it and to re-install the app. Still the exact same thing. Everytime I try to activate the armor protection I get a message stating that it timed out and failed to activate and try again. I have a RAX45 / AX4300 Nighthawk Router. IS there anything that can be done to fix this?
try turning remote management off and then back on or vice versa
- edjenn1998Aspirant
did not work. It was off so I turned it on and then back off. No good. I trying it on. no good.
Did you try contacting bifdefender support (what armor's based on) at all?
https://www.bitdefender.com/consumer/support/
You can also try a factory reset of the router and reinstalling it.
Are you using the app for setup?
