rgpriest
Jun 12, 2021Aspirant
Bitdefender Armor and System Mechanic
HAs anyone had any experience runnig Armor, Bitdefender and iolo's System Mechanic Ultiate Defense?
Hello rgpriest,
We are not aware of any issues regarding NETGEAR Armor and System Mechanic. However, if you do run into any issues I would recommend contacting our support team using the link below as newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/contact.aspx
Christian
- Christian_RNETGEAR Employee Retired
Hello rgpriest,
Would you mind telling us more and what you're trying to accomplish?
Regards,Christian
- rgpriestAspirant
I recently purchased the Nightwhaw router/satellie system MS 63 i believe as well as the Nighthawk Telephony Modem. I was looking to install Armor and Bitdefender on our devices. Some of our laptops have iolo System Mechanic Ultimate Defense. I know that runnig two security programs can cause conflicts so I wanted to see if I should remove System Mechanic before running Bitdefender
Hello rgpriest,
Christian
