ggarris1's avatar
ggarris1
Disable Armor on singular device
How do I disable armor on a singular device and not affecting other devices in network? I want protection on all devices except one that needs freedom to go anywhere without restrictions. Operating with Mac OS14 and using Nighthawk app. My Android TV box needs freedom to all Urls.
    • ggarris1's avatar
      ggarris1
      My whole home network for my trip-band router is controlled by Nighthawk and uses Armor. I only see where you select Armor ON for complete network or OFF.
      Thanks
      • FURRYe38's avatar
        You can only enable or disable Armor from the mobile app that covers the entire network.
