NG7856
Jun 09, 2025Guide
Disable Netgear ARMOR or cancel Subscription use Web browser
I have to use a web browser to configure my new R700S router. (Smart phones are not allowed in this area.) I could not find a RS700 to purchase so I purchased the RS700S. I do not need or want the...
Jun 09, 2025Guru - Experienced User
Something you can only do thru the NH app. Check on the app under subscriptions.
You can disable Armor as well from the NH app. Under Setting/Security.
If you need more help, you'll need to contact NH support: Armor Help and Information FAQ | NETGEAR Communities
