GreenBadger
Mar 18, 2019Follower
How do I remove this garbage from my router?
Updated to the latest Orbi firmware and enabled the trial of armour.
Today the router is blocking my access to legitimate websites falsly claiming they are phishing sites.
I canot see any way to remove the armour service or educate it to the error of its ways
Barring a factory reset on my orbi system how can I get rid of this?
- NobodynewAspirant
- NobodynewAspirantEveryone forgets to tell you that when you unplug the router you need to open the nighthawk app hit the home button and open settings, wait until the WiFi it’s up before the router has established a cloud connection ( the internet ) open the anywhere access and disable it!!!! Only then can you open the security tab and turn the switch off for nether armor, I don’t have time to reset my world personally . Hope this helps next time
- nooneeverywhereInitiate
unable to disable armor (errors out because it took more 60 sec) trying to allow the site (error please try again... same error)
- CaptHindsightAspirantTry flushing your DNS cache to see if you can reach the site inside of the timeout window. This timeout error could be a plethora of connectivity issues; but, to flush your cache on a Windows PC:
Press Windows key + R
Type ‘CMD’ and press enter to open command prompt CLI
Type: ipconfig /flushdns and press enter
Try to reach the landing page again
