downsc
Apr 01, 2019Initiate
How to disable / deactivate Armor on RBR50?
Hey team,
I've enabled Armor on my Orbi RBR50 but decided I no longer wish to use it, is there a way to remove it without needing to factory reset the entire device
Apr 30, 2019Guru - Experienced User
Also can find out on the Armor forum as well:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
- danny07Apr 30, 2019Tutor
I searched there and did not find the answer. I did see posts in the Armor forum with the same question, and you replying that people should look in the Armor forum. Muy helpful.
Google brought me to the answer above.
