downsc
Apr 01, 2019Initiate
How to disable / deactivate Armor on RBR50?
Hey team,
I've enabled Armor on my Orbi RBR50 but decided I no longer wish to use it, is there a way to remove it without needing to factory reset the entire device
Apr 30, 2019Guru - Experienced User
Thanks for letting us know. :smileywink:
