downsc
Apr 01, 2019Initiate
How to disable / deactivate Armor on RBR50?
Hey team,
I've enabled Armor on my Orbi RBR50 but decided I no longer wish to use it, is there a way to remove it without needing to factory reset the entire device
SimonBelgium
Apr 29, 2019Guide
Found it...
I'm using the iOS app, and here's where it's at...
When you're logged in, you're on the page with the big icons (you'll see the Armor Security icon as "Activated")
Now click the HOME icon on the top left.
Click SETTINGS
You should see a menu with Router Settings, Wifi Settings, etc
From the list, select SECURITY
Now you should see a toggle switch to turn OFF the Netgear Armor.
Even though the main icon will still say ACTIVE, it will be off. If you open the orbilogon.com page on your computer, you'll see it's off.
Sven62
May 05, 2019Tutor
Thank you!
