downsc
Apr 01, 2019Initiate
How to disable / deactivate Armor on RBR50?
Hey team,
I've enabled Armor on my Orbi RBR50 but decided I no longer wish to use it, is there a way to remove it without needing to factory reset the entire device
DexterJB
Jul 19, 2019NETGEAR Moderator
Southy
Jul 20, 2019Tutor
Thanks Dexter for the rather pointless private message. There's no point sending a message offering help if Netgear ignore both my replies giving my telephone number and e-mail address as requested. What is the phone number for tech support?
