downsc
Apr 01, 2019Initiate
How to disable / deactivate Armor on RBR50?
Hey team,
I've enabled Armor on my Orbi RBR50 but decided I no longer wish to use it, is there a way to remove it without needing to factory reset the entire device
BWest1
Mar 15, 2020Star
I can't disable Armor... When I toggle the switch in the app, I there is a "Disabling NETGEAR Armor." screen which appears for a period of time witht he swirly icon indicating waiting for something to occur. Then an error message "Process is taking too long (more than 60 secs), Try again!" or "Sorry, the action was failed. Please try again."
So how can I get rid of this crap which is killing my internet performance? I've tried this at least 50 times, can't get past the error messages.
iOS app version 2.4.21.5 ... Firmware 2.5.1.8
Mountainmanwv
Jun 07, 2020Initiate
Have the same issue. In any disable mergers armor. When I slide to turn off I get error process taking to long over 60 sec. need this fixed. As my internet keeps disconnecting.
