Grafixmac
Jul 31, 2026Tutor
I have an old router which has been tossed out
Has anyone had any resolution to this problem? I'm in the same boat. I have an old router which has been tossed out, and I am not able to contact support, because in order to contact support you have...
schumaku
Jul 31, 2026Guru - Experienced User
Grafixmac wrote:Has anyone had any resolution to this problem?
Almost as impossible to find an effective question - a problem that somenody has found a tossed out Netgear router or what?
Grafixmac wrote:I'm in the same boat. I have an old router which has been tossed out, and I am not able to contact support, ...
Do you have a real question the community members related to Netgear routers in general, or related to NEtgear routers supporting Netgear Armor specifically?
Every Netgear router has a product label, plus some more indications which might help us to identify that router - so start with:
- Netgear model (from the proiduct label) Netgear model description from the integrated Web UI?
- What problem, what was the exact question again please?
Grafixmac wrote:NETGEAR_Support ???
This is an ancient account, probably created a long time ago by a Netgear employee, but no longer active, read: Retired. So this is certainly not an active Netgear Support account...
Grafixmac wrote:because in order to contact support you have to pay for the subscription service, so support for Netgear is impossible
Have a question related to Netgear Armor as you posted in this section?
Which products support NETGEAR Armor?
Most devices Netgear ever made are documented:
Where can I find information about my NETGEAR product?
Netgear Consumer Routers -> https://www.netgear.com/support/home/downloads
Netgear Business Routers -> https://www.netgear.com/support/enterprise/
schumaku
Aug 01, 2026Guru - Experienced User
According to Grafixmac earlier community posts, one might guess you are talking of a RAX70 and Netgear Armor.
Grafixmac wrote:I am not able to contact support, because in order to contact support you have to pay for the subscription service, so support for Netgear is impossible.
Is your Netgear Amor subscription simply expired, or does Armor not work as epected?
On my.netgear.com -> Get Support -> Open a support case ...
...tick "I have a subscription service", select [Armor] from the list...
...then you can select either [Call Support] (or [Chat with us])...
Describe the issue...
...after entring the issue desciption, the [Next] button will become active, ...
You will get a phone number (depending on your market, country, ...) for
Home and Mobile WiFi Products (Orbi, Nighthawk, NETGEAR Armor, WiFi extenders and mobile hotspots, etc.):
...and a Case Number (you might have to key in on your phone if requested.
Same details are sent to you by email, too.
That much about contactoing Netgear Support is impossible.
