Grafixmac
Jul 31, 2026Tutor
I have an old router which has been tossed out
Has anyone had any resolution to this problem? I'm in the same boat. I have an old router which has been tossed out, and I am not able to contact support, because in order to contact support you have...
schumaku
Jul 31, 2026Guru - Experienced User
Grafixmac wrote:Has anyone had any resolution to this problem?
Almost as impossible to find an effective question - a problem that somenody has found a tossed out Netgear router or what?
Grafixmac wrote:I'm in the same boat. I have an old router which has been tossed out, and I am not able to contact support, ...
Do you have a real question the community members related to Netgear routers in general, or related to NEtgear routers supporting Netgear Armor specifically?
Every Netgear router has a product label, plus some more indications which might help us to identify that router - so start with:
- Netgear model (from the proiduct label) Netgear model description from the integrated Web UI?
- What problem, what was the exact question again please?
Grafixmac wrote:NETGEAR_Support ???
This is an ancient account, probably created a long time ago by a Netgear employee, but no longer active, read: Retired. So this is certainly not an active Netgear Support account...
Grafixmac wrote:because in order to contact support you have to pay for the subscription service, so support for Netgear is impossible
Have a question related to Netgear Armor as you posted in this section?
Which products support NETGEAR Armor?
Most devices Netgear ever made are documented:
Where can I find information about my NETGEAR product?
Netgear Consumer Routers -> https://www.netgear.com/support/home/downloads
Netgear Business Routers -> https://www.netgear.com/support/enterprise/
Grafixmac
Aug 01, 2026Tutor
In order to open a Support Case, as displayed on the Netgear page to Contact Support, and also in the very screen shot you posted, it states very clearly:
"Requires an entitled product or subscription".
My (old) product (which was registered and has a serial number) is no longer listed in the drop down menu (my current router and modem are), therefore I cannot choose the old item to get support.
I also do not have AirCard.
I also do not have a subscription.
The issue is that this old product (as explained by the OP) is still listed in my Netgear Armor dashboard.
I do not want it in my Netgear Armor dashboard. Why? Because it is in some landfill somewhere.
There is NO option to remove it.
I cannot create a support case or contact customer support for the reasons explained above.
I am going around in circles.
The EASIEST fix would for someone at Netgear to simply allow the option in the Netgear Armor dashboard, "TO REMOVE DEVICE". Not hard.
- schumakuAug 01, 2026Guru - Experienced User
This feature is available, look here:
How do I remove an inactive or vulnerable device in NETGEAR Armor?
Admit, it's not in the App...
- GrafixmacAug 01, 2026Tutor
It's also not on the dashboard. I've looked, and looked. And then I've looked again. I just looked again now. There is no option. There are no 3 dots. It's not there.
To confirm, I am at armor.netgear.com.
I have logged in.
I am on the portal dashboard.
There is no option to "see all devices on this router".
There are no "ellipses".
There is nothing else on the Dashboard page besides a "threat indicator" and "security news"
If I go to "My Devices", I literally have NO options to do ANYTHING, except select which device I want to select. There is nothing under "Settings" and there is nothing under "Filter by" that allows me to delete this **** device.
- StephenBAug 01, 2026Guru - Experienced User
Are you talking about an RS400? Or are you talking about a different router???
