eroyal
Aug 27, 2025Follower
I renewed Armour with BitDefender and I no longer have access to "Access Contol"
I have the RS7200 router which I purchased in June, 2024. I renewed Armour with BitDefender and I no longer have access to "Access Contol" I had it and used it prior to the renewal. I paid the higher renewal price. The msg I get is to use the NightHawk App, which I have. I am unable to locate it on the NightHake APP. On this forum it was advised to use the ORBI app. I downloaded it and I get the msg that my router is not supported by ORBI. WHERE IS ACCESS CONTOL on a RS700 year old router?
1 Reply
Netgear has two product lines: Nighthawk and Orbi (mesh)
There are separate smartphone apps for Nighthawk and Orbi. "it is what it is".
RS7200 does not appear to be a Netgear product number. There is an RS700, which describes Access Control on page 55 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RS700S/RS700_UM_EN.pdf
