stevefxp's avatar
stevefxp
Apprentice
Apr 21, 2019
Install Bitdefender Failure
Hello all,
I have actived Netgear Armor on my Orbi and now am trying to extend protection to a user outside of my Orbi. I am able to get the software installed but when I try to activate it with my Netgear id/pswd it comes back "unable to connect to the server". This has happened for the last two days. Anyone seen this?
Steve
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi stevefxp,
    Welcome to the community!
    Is that device using iOS or Android? Please provide a screenshot of the error since that will help us. You can also try re-installing the app. Can you also continue to add other devices within your network?
    Looking forward to your response.
    Dexter
      • stevefxp's avatar
        stevefxp
        Apprentice
        Yes sir...had to wait a couple of hours and then it was able to login successfully.
