WinterMute's avatar
Aug 05, 2020
Interacting with Armor once it's enabled
Turning on Armor killed my home network (Modem/Internet was fine) until a power cycle.
This router has never had a connection break like that--my ISP has outages from time to time, but this is the first the router did it.
Sometime last night, Armor killed my home network again.
If I go to the Armor portal at armor.netgear.com, or I log into my router at routerlogin.net, neither gives me any sort of insight as to what went wrong, or a report that lets me choose to address whatever it is that caused Armor to lock everybody out.
I have overnight processes sometimes that need to run. I need to know I can rely on Armor to either maintain connection or give me some information about what happened and a path to address it.
    • WinterMute's avatar
      WinterMute
      Star
      Thanks Christian_R:
      It's a RAX200, firmware 1.0.2.98, and I've set up a ticket with support.  I didn't realize at first that there's a particular way to walk through Support --> Other --> Armor that will let you get support without paying for out-of-warranty support.
      With luck this will solve the problem, but I think long-term there needs to be some sort of logging or visibility so the user (who, if they're looking for logs and inside the router or the Armor portal, is already a pro-level user) can have the ability to address what's causing the problem.
