Nissanclubman
May 26, 2019Aspirant
Moving SC101 to another PC
I'm sure this is a straight forward task but just wanted to double check the procedure.
Existing SC101 was working fine on a windows XP PC then PC died. I then want to setup the SC101 software on a secnd WinXP PC and can't find the proedure. Can anyone point me in the reight direction to download the SC101 software and where I can find the procedure to setup it up and get my drives runing in the new PC. Tks in advance.
- DexterJBNETGEAR Moderator
Hi Nissanclubman, welcome to the community. The link below may help out.
https://www.netgear.com/support/product/SC101.aspx#download
Dexter
- NissanclubmanAspirant
Thanks Dexter,
I'll download the SCM and install it tonight.Is there a thread that you can point me to that describes how to setup the drives to be visible in the SCM or will they be automatically setup?Will start with installing the SCM software and see how things appear.Kind Regards Richard- DexterJBNETGEAR Moderator
This link may help but for additional resources, the link below has some helpful documents.
https://www.netgear.com/support/product/SC101.aspx#docs
Dexter
