emily423
Sep 07, 2025Tutor
My Website Is Being Blocked by Netgear Router Security
Hi everyone, I run a small website and recently discovered that several visitors using Netgear routers can’t access it. When they try, they get a warning that the site is “blocked” or “unsafe.” Some ...
emily423
Sep 08, 2025Tutor
Thanks for the quick reply! The main router that one of my visitors reported the issue on is the Netgear RAX45 Nighthawk AX6, and another user mentioned it happening with a different model as well (unfortunately I don’t have that exact one yet). I’m wondering if this might be a model-specific issue or something broader across routers running Netgear Armor/Parental Controls. Do you think sharing the exact firmware version would also help narrow it down? Should I share the site URL with you so that you can check and confirm if it's happening on your end?
- FURRYe38Sep 08, 2025Guru - Experienced User
Send me a PM with URL and I can test.
- emily423Sep 09, 2025Tutor
What is PM? Here it is please check and guide me thetexasroadhousemenu.com
- FURRYe38Sep 09, 2025Guru - Experienced User
So this site is not accessible by any devices connected to these routers if Armor is enabled?
