michalmsz's avatar
michalmsz
Follower
Aug 15, 2019
NETGEAR Armor activating problem.
Hi,
I am traing to sign in to the Neatgear Armor but I this massage poping up:
The NETGEAR Armor security activation process failed due to some reason.
Please contact Technical Support for more details.
Please help, thank you in advance
Best regards
michal
  • My Netgear Armor is failing to activate.
    I have completed subscription and activation on the armor website but the Nighthawk App keep saying fail to activate.
    How can I get Armor back on the app?
  • Hi I don’t have Netgear armor on my router but it says I have a trial run. So whenever I try to activate it, it tells me there’s and error I don’t know what it is any suggestions?
  • Trying to activate returns "failed to activate" try again. I've updated the firmware, rebooted the system, no luck.
  • I bought the armor and was using my WiFi. Could not access Netgear app and router so did a reset. On the app it says their are 2 routers. Original with serial number and now a router with local access. Anyway, suddenly says WiFi has weak security and again not able to access Netgear. Reset through Netgear site and still can’t get on. Says I need to sign in to network on my router but I am on my WiFi. I also do not think my armor subscription I paid for transferred to the new local network. Why is it local
    With no serial number?? I’m pretty fed up with the whole thing. How do you cancel if you can’t even access the Netgear app?? I paid for subscription and not even sure it’s on this new local network that was setup. Help!!
  • I also cant activate armor
    I have an orbi rbk753
    I have tried alot of things
    • PigletRider's avatar
      PigletRider
      Apprentice
      My issue was finally resolved by the techs at Bitdefender.  As it turns out, I have 2 (Don't ask me how.) Netgear accounts.  When I renewed, it fell under account "A" using my "A" e-mail address.  As it turns out, my router (according to Bitdefender) is registered using my "B" e-mail address.   Hmmm... When I checked... sure enough.  I have 2 Netgear accounts.  I was able to log into both of them individually.
      My "B" e-mail address was my Google e-mail.  Somehow, along the Netgear way, I must have created 2 Netgear accounts.  I wanted my router registered to my "A" account but the Nighthawk app kept insisting that it was registered under my "B" account.  Even after uninstalling/re-installing the app, it still insisted that I was registered with "B."   Bitdefender said I was "A" when I renewed Netgear Armor.  I was logged into the Nighthawk app using the "A" account.  This would not work for some reason.
      It was only when Bitdefender moved my registration to my "B" account that Armor was finally activated.  I've decided to leave this as is, until and when Netgear decides to cancel my "B" account and the fight begins anew.
      • Frank_v_H's avatar
        Frank_v_H
        Trying everything to get Armor running, but still it will not activate in the app.
        1. I bought this router as "Second chance" (it was returned to the store, and then re-sold)
        2. Probably due to this, the router has had a factory reset, couding the armor status to be "Expired free trial period".
        3. OK, I could understand that, but now after almost a year  I decided to buy a subscription anyway.
        4. I ordered it through the app, and the process seemed to work fine.
        5. At the https://armor.netgear.com site, I can see my router is there by it's serial number registered on bitdefender (green dot).
        6. In the app and in the web interface Armor keeps disabled already for a week now.
        7. Did a factory reset, no result.
        8. Switched "Anywhere" off and on again, no result
        9. Looked all over the internet for a solution, and tried everyting .. no result ...
        My firmware version is  V1.0.6.116_2.0.54 (latest downloadable from UI)
        Anyone who could help me out here?
