mgdurand1
Mar 17, 2019Luminary
Netgear Armor and another antivirus
Just did the upgrade on my Orbi router and satellites to 2.3.0.32. Gives me the offer to try Armor for 90 days. Did a very little bit of reading and it appears to be a Bitdefender software system that inlcudes antivirus proteciton. I know you are not really supposed to run 2 antivirus pprograms at the same time. Is the same true for this solution? I run an antivirus as well as a couple of anti-malware programs. Curious to see if anyone has seen anything on this. Thanks.
Hi mgdurand1 ,
Welcome to the community!
That's an excellent question. With NETGEAR Armor, you can use it alongside the Bitdefender Total Security that can be installed on your devices. As this is also an anti-virus software that will share your device system resource, it is best to not have it run with a similar software since it may cause conflicts.
Dexter
Community Team
I would post here about this:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
- DexterJBNETGEAR Moderator
Hi mgdurand1 ,
Dexter
Community Team
