jamesharwell's avatar
jamesharwell
NetGear Armor and Bitdefender Box 2
Do I need the NetGeat Armor if I have BitDefender Box 2?
  • No. I assume you have Bitdefender installed on devices as well. You do that with Armor. Basically Armor and Bitdefender are doing the same or similar things. No need to dupicate. Bitdefender box is probably a better solution anyway.
    • jamesharwell's avatar
      jamesharwell
      Thank you for the response. I'm thinking the same as you. I just didn't see any info on bitdefender or netgear's site
