DayHawk96
Aug 01, 2022Aspirant
Nighthawk ax6000 not working with xfinity stream
Upgraded to the nighthawk cax80 to get rid of the rented router I had, now xfinity stream won't work over this router/modem? They have xfinity on the box and is listed on their suggested site. Super...
- Aug 02, 2022
The problem was netgear armor. It was blocking the stream from xfinity for whatever reason.
Hopefully they can fix that feature because I liked the security...
Aug 02, 2022Guru - Experienced User
Its only xfinity stream not working?
Are you streaming it using their flex box or what are you using to stream with it?
what actually happens when you try to use it?
