DayHawk96
Aug 01, 2022Aspirant
Nighthawk ax6000 not working with xfinity stream
Upgraded to the nighthawk cax80 to get rid of the rented router I had, now xfinity stream won't work over this router/modem? They have xfinity on the box and is listed on their suggested site. Super...
- Aug 02, 2022
The problem was netgear armor. It was blocking the stream from xfinity for whatever reason.
Hopefully they can fix that feature because I liked the security...
DayHawk96
Aug 02, 2022Aspirant
Aug 02, 2022Guru - Experienced User
So with Armor disabled, the stream is now working?
- DayHawk96Aug 02, 2022Aspirant
Yup as soon as I turned off Armor the stream started right away. It only affected xfinity stream all the rest of my streaming services worked just fine... Hopefully they can fix this issue.
- FURRYe38Aug 02, 2022Guru - Experienced User
Something I would make contact with NG support about to let them know.
- plemansAug 02, 2022Guru - Experienced User
You could go into the armor setup and see if its a specific url thats being blocked.
https://kb.netgear.com/000061715/How-do-I-unblock-URLS-in-NETGEAR-Armor
