breaksfr123's avatar
Oct 20, 2025
No Endpoint Security Extension macOS 26
Hello,
I did a wipe and fresh install of macOS 26 after running in to some problems on my MacBook Pro, where I had Netgear Armor installed.
Now after installation, when I look under General -> Login Items and Extensions -> Category there is no Endpoint Security Extension option, as though the extension has not been installed.
I still see Netgear Armor Agent in Login Items and Privacy and Security, just no extension.
In terms of troubleshooting, I have uninstalled, restarted my Mac, installed Armor, restarted again, and still no extension.
Any thoughts?
Thank you
1 Reply
  • FURRYe38's avatar
    Possible Armor may not be fully supported on OSX 26 since it's pretty new.
    Something to check with Armor support about and see.
