kd4hsh
Jun 16, 2026Follower
On new RS100 installation I cannot find any way to disable Netgear Armor
June 2026, On new RS100 installation I cannot find any way to disable Netgear Armor. (I did activate the Nighthawk Armor free trial. Is that the reason I cannot disable?)
Jun 17, 2026Guru - Experienced User
- Connect to your router's WiFi network.
- Launch the app and tap the Home/Cloud icon in the top left corner.
- Go to Settings > Security.
- Toggle the Enable NETGEAR Armor slider to the Off position
