Fit_to_be_Tide
Nov 04, 2025Aspirant
Orbi 970 Series VPN / Armor Plus
I have an Orbi 970 Series BE27000 (2 satellites) that was purchased in Feb 2025. I also have a Home Assistant installation controlling numerous IoT devices running on this wireless network. To date...
Nov 04, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- Fit_to_be_TideNov 04, 2025Aspirant
RBE971 firmware version: V9.13.1.2 (same for both satellites).
I'm not sure about the ONT. (I'm at work).
The cable between the ONT and router is CAT7.
