ftgdc2018
Dec 26, 2018Follower
R7000P router and Netgear ARMOR issues
I am a month late in renewing my ARMOR subscription. First off, it was hell and took me over an hour to find out I had to purchase from Bitdefender directly. From there, I recieved an activation code...
DexterJB
Jan 08, 2019NETGEAR Moderator
Hi ftgdc2018,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
- ChemicalGilroyApr 16, 2019Star
Can you post the reply so that everybody can see? After the most recent update Armor login is **bleep**ing broken. It works fine on the Nighthawk app and says I am signed into Armor. But when using the web portal from my computer browser it says Armor is not activated on my device and when I try to activate it by signing into my account, it keeps failing. So as the OP asked, am I protected or not?
- ChemicalGilroyApr 17, 2019Star
Please disregard. A factory reset solved the issue.
- squirtstApr 18, 2019Guide
I would like the answer to this as I am having the same issue with Bit Defender not activating through the web portal and I have a LOT of customization with IPs on my router, not interested in doing a factory reset.
