nateaf's avatar
nateaf
Follower
Aug 12, 2019
RBK50 Dropping internet with armor
When I enable Armor on the Orbi, internet will drop in 24 hours or less, and the only way to restore it is to reboot the router.  With Armor disabled, I do not have any issues with the internet.  I have performed a factory reset of the router, with the same result.  Any suggestions?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi nateaf, welcome to the community! I have sent you a message. Please check your inbox.
    Dexter
  • Hi nateaf . I was just going over some older unread posts and came across yours. I don't know if you were able to resolve your issue, but I will share my own experience with you if only for the benefit of other users perhaps. The dasy chain option is enabled by default on the Orbi router. If you only have one satellite, disabling it will get rid of the internet drops -- at least, this has been my experience. Once I installed a second satellite, I re-enabled the daisy chain option and that resulted in much better reach over the whole network, with no internet drops whatsoever. My Armor trial has since run out and I am still sitting on the fence as to whether or not I should buy the one-year subscription.
