FlyingSoda
Sep 11, 2025Aspirant
Cannot connect to Robot Vacuum after Armor Plus subscription
Hello, Yesterday I have subscribed to Armor Plus for my Orbi WiFi Mesh RBR760. I am now unable to manage / start any of my home robot vacuum cleaners. When I want to see the maps I get an erro...
- Sep 13, 2025
Hello all, I would like to mention the issue is resolved.
I have uninstalled Netgear Armour and the Roomba iRobot and Roborock apps, then reinstalled Netgear Armour and then the robot vacuum apps again. In the case of Roborock it worked right away, in case of the Roomba iRobot I had to do a reset of the vacuum robot and after the first run the map was visible again.
Happy to report all good and this thread can be closed. Many thanks for your input, FURRY and Plemans.
FlyingSoda
Sep 13, 2025Aspirant
Sep 13, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- FlyingSodaSep 13, 2025Aspirant
Hello FURRYe38,
Thanks for the tip about backing up the configuration. I will follow up on that. And I will mark the thread as solved. Thanks again.
