downsc
Apr 01, 2019Initiate
How to disable / deactivate Armor on RBR50?
Hey team,
I've enabled Armor on my Orbi RBR50 but decided I no longer wish to use it, is there a way to remove it without needing to factory reset the entire device
Christian_R
Apr 02, 2020NETGEAR Employee Retired
Hello Community,
Please refer to the article linked below on how to turn of Armor using the Nighthawk/Orbi app. If you still run into issue(s), please send me a private message with your name, email, phone, preferred contact time, and serial number.
Thanks,
Christian
Mountainmanwv
Jun 08, 2020Initiate
I have tried the instructions and it doesn’t work
- Christian_RJun 10, 2020NETGEAR Employee Retired
Hello Mountainmanwv,
May you send me a private message with your contact info and serial number. I'd like for our support team to reach out to you.
Christian
