Grafixmac
Jul 31, 2026Tutor
I have an old router which has been tossed out
Has anyone had any resolution to this problem? I'm in the same boat. I have an old router which has been tossed out, and I am not able to contact support, because in order to contact support you have...
Grafixmac
Aug 01, 2026Tutor
We are going around in circles. The 2 of 2 device is my new, currently functioning, actively registered device and bears no weight to the question at hand, which is how do I remove the RS400 from the list of devices at armor.netgear.com. It does not matter why it no longer functions... whether it stopped working, was destroyed by a meteor, or I simply wanted to upgrade to my new device.
Aug 01, 2026Guru - Experienced User
OK, Anything with support and accounts needs to be handled by NG support. All this a beyond forum help. We do not have access to those services.
Good luck then.
