emily423
Sep 07, 2025Aspirant
My Website Is Being Blocked by Netgear Router Security
Hi everyone, I run a small website and recently discovered that several visitors using Netgear routers can’t access it. When they try, they get a warning that the site is “blocked” or “unsafe.” Some ...
emily423
Sep 11, 2025Aspirant
Yes, that seems to be the case . when Netgear Armor is enabled on these routers, my site either gets blocked completely or shows a warning that it’s unsafe. The strange part is that the issue doesn’t happen on all pages; for example, the homepage may load, but some menu or coupon pages are flagged and blocked. When Armor is disabled, the site works fine across all devices, so it really looks like a misclassification by the security system. I think it is happening on my side only. Do you think providing the exact firmware version and router logs from affected users would help in narrowing this down?
