emily423
Sep 07, 2025Aspirant
My Website Is Being Blocked by Netgear Router Security
Hi everyone, I run a small website and recently discovered that several visitors using Netgear routers can’t access it. When they try, they get a warning that the site is “blocked” or “unsafe.” Some ...
Sep 11, 2025Guru - Experienced User
emily423 wrote:Yes, that seems to be the case . when Netgear Armor is enabled on these routers, my site either gets blocked completely or shows a warning that it’s unsafe
JWS9518 isn't having any issues with Armor turned on. So there might be other internet security software running on the PCs that is responsible. Did you ask one of the folks to disable Armor for a bit and then see if the problem goes away?
As an aside, the overall look of the site is quite close to the Texas Roadhouse website (including using their trademark), and the disclaimer at the bottom of the page is easy to miss. That might be one factor in the mis-classification.
