juliee78
Feb 09, 2026Aspirant
Website Getting Blocked by NETGEAR Armor
Hi everyone, I’m facing an issue where my friend website is being blocked by NETGEAR Armor, and I believe it may be a false positive. Users connected through NETGEAR routers with Armor enabled are un...
- Feb 09, 2026
Try a Google search on "netgear armor false positive"
I could not paste the results. they were:
in the Orbi/Nighthawk app go to the Security tile > Threats Blocked, tap the URL and select "Unblock Access"
If a URL is consistently blocked, submit it for review via the Bitdefender false positive form:
CrimpOn
Feb 09, 2026Guru - Experienced User
