TommyRND4000's avatar
TommyRND4000
RND4000 (ReadyNAS NV+
Hi,
My ReadyNAS RND400 has died for some reason.  Netgear send me an replacement board last year after the unit died at that time.   I cannot seem to get access to this support unit this time around.
If I was to buy another unit, has to be a four disk unit I guess, will the drives work?  I see on https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNAS-RND4000-Move-HDD-into-another-Identical-Unit/m-p/1481643 that they will work but the RND4000 is not available in UK to the best of my knowledge.
Anyone know how to contact Netgear Support directly?
TommyRND4000
  • Hi TommyRND4000
    Welcome to the Community!
    ReadyNAS NV+ or RND4000 is already discontinued (EOL) and is replaced by the OS 6 models like the RN400 series and up.
    Inserting your drives on the same unit will just need to be booted normally and your data should be accessible after a successful boot. The problem might be with finding a good working unit on a reasonable price point. IMO, it is much better if you upgrade your unit and have Support assist you on getting your Data back though Data recovery services might be needed. You can check this article on migrating the data from a Legacy NAS to OS 6 NAS.
    You can contact Support through your MyNETGEAR portal, just login and register your device and create a Support case.
    Hope this helps!
    Regards
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi TommyRND4000
    Hope this helps!
    Regards
