FattiesGoneWild
Feb 24, 2026Guide
RS700 Netgear Armor confusion….
Very confused with Netgear Armor. What exactly is this thing? My confusion lies with how it’s described. Is it full protection for all devices at the router level, including virus/malware protection?...
Feb 25, 2026Guru - Experienced User
Part of the subscription comes with device level software you can install.
Its powered by bitdefender (pretty solid company).
Here's how they go over it.
https://www.bitdefender.com/consumer/support/answer/27902/
