runandwritebq's avatar
Jul 30, 2024
Scan with Netgear Armor not working
I like to scan anything I download, and I usually do so by right clicking on the item in my folder, selecting "Netgear Armor" and then selecting "Scan with Netgear Armor," but yesterday that stopped working. Re-installing the program hasn't fixed it. Perhaps the program is broken? I'm using Windows 11.
  • ineke's avatar
    ineke
    Nov 01, 2024
    FOUND WORKAROUND solution.In case anyone else encounters this problem, solution below:
    It works when activated from the "old-windows layout" right click menu accessible via right click>more options
    So the netgear armour functions per file/folder can be activated by:
    >Right click file
    >more options (bottom option in the rightclick menu)
    >netgear
    >NA scan or shredder
    • runandwritebq's avatar
      runandwritebq
      I tried that before posting here. I had even tried uninstalling and reinstalling, and nothing. Now it seems to work sometimes. A couple of days ago it worked, today it doesn't again.
      • FURRYe38's avatar
        Might contact Armor support about this.
