juliee78
Feb 09, 2026Aspirant
Website Getting Blocked by NETGEAR Armor
Hi everyone, I’m facing an issue where my friend website is being blocked by NETGEAR Armor, and I believe it may be a false positive. Users connected through NETGEAR routers with Armor enabled are un...
- Feb 09, 2026
Try a Google search on "netgear armor false positive"
I could not paste the results. they were:
in the Orbi/Nighthawk app go to the Security tile > Threats Blocked, tap the URL and select "Unblock Access"
If a URL is consistently blocked, submit it for review via the Bitdefender false positive form:
CrimpOn
Feb 09, 2026Guru - Experienced User
juliee78
Feb 11, 2026Aspirant
https://www.bitdefender.com/business/support/en/77209-343057-submitting-sample-files-and-websites-for-analysis.html
Thanks for the pointers, that’s really helpful.
I wasn’t aware you could manually unblock a specific URL directly from the Orbi/Nighthawk app under Security → Threats Blocked, so I’ll have my friend try that first as a temporary workaround. Submitting the domain through the Bitdefender false positive form also sounds like the right long-term fix if Armor keeps flagging it incorrectly.
I’ll go ahead and submit the site for review and monitor whether the block gets lifted after analysis. Appreciate you sharing the exact steps and link that gives me a clear path forward.
