NetUSERW
Apr 25, 2018Tutor
Can't setup Circle Account, "Can't connect to circle" error.
Got this router for its parental control features. Unfortunately, it has taken so much time trying to set it up, still without success.
No luck setting up circle account, I keep getting "can't con...
RIXX77
Aug 14, 2018Initiate
Hi, Im getting the exact same issue on the R8000?
I had the R7000, updated to the R8000 because everything says that it is compatible with Circe but I cant connect.
I have a Premium account and its being wasted!!!
Latest firmware does not help either.
I select it with Netgear Genie, open the APP (after connecting to the routers wifi) go through the options, everything looks happy until it goes to connect....
"Cant connect to circle", What now?
NetUSERW
Aug 14, 2018Tutor
Sorry to hear that. After several days/weeks of troubleshooting with tech support, firmware downgrades and upgrades, I was told that Circle is not supported in my country (I'm in Taiwan), hence, cannot connect.
I only wish that Netgear made it clear in their product description the locations which Circle is supported. If I knew it was not supported in my country, I wouldn't have bought this router. Thumbs Down.
