pugcoin
Nov 08, 2020Tutor
Circle 1st Gen App (2.1.10) arbitrarily blocking websites on RBR50 with 3x RBS50 (firmware 2.7.1.60)
Hi I upgraded our Orbi RBK50 system (2.7.1.60) and Circle 1st Gen (2.1.10) to latest firmware versions to address intermittent web disconnections. It has not fixed the problem. Disabling Circle fixes ...
- Nov 12, 2020Hi thanks. I did upgrade to the latest firmware 2.7.1.60 for the router and satellites. Bad connections with Circle enabled; works perfectly when disabled.
I will try router factory reset.
L3ftDr1ft
Nov 08, 2020Initiate
I’m experiencing the same issue for about a week. Circle blocking approved sites, upgraded to firmware 2.5.2.4, did not fix. Also disabled private address on all iPhones/devices to ensure that it’s getting the right profile. One thing I noted is that the blocked sites aren’t showing in the “filtered” tab for any profile...
Would be interested to hear if anyone else experiences the same issue, and perhaps any fixes that come out.
- Goon2k2000Nov 09, 2020AspirantAdd me to the list. I'm having this exact same problem.
