pugcoin
Nov 08, 2020Tutor
Circle 1st Gen App (2.1.10) arbitrarily blocking websites on RBR50 with 3x RBS50 (firmware 2.7.1.60)
Hi I upgraded our Orbi RBK50 system (2.7.1.60) and Circle 1st Gen (2.1.10) to latest firmware versions to address intermittent web disconnections. It has not fixed the problem. Disabling Circle fixes ...
- Nov 12, 2020Hi thanks. I did upgrade to the latest firmware 2.7.1.60 for the router and satellites. Bad connections with Circle enabled; works perfectly when disabled.
I will try router factory reset.
snaptopixel
Nov 09, 2020Tutor
I'm on an RBR40 with Version 2.6.7.0 with the same issues. Sites that are allowed on my profile are being blocked willy nilly.
