pugcoin
Nov 08, 2020Tutor
Circle 1st Gen App (2.1.10) arbitrarily blocking websites on RBR50 with 3x RBS50 (firmware 2.7.1.60)
Hi I upgraded our Orbi RBK50 system (2.7.1.60) and Circle 1st Gen (2.1.10) to latest firmware versions to address intermittent web disconnections. It has not fixed the problem. Disabling Circle fixes ...
- Nov 12, 2020Hi thanks. I did upgrade to the latest firmware 2.7.1.60 for the router and satellites. Bad connections with Circle enabled; works perfectly when disabled.
I will try router factory reset.
franktribe
Nov 09, 2020Apprentice
Same problem.
I have an RBR50 firmware 2.5.2.4
Built-in Circle into the router, paid version. In the Webinterface of the router it says the Circle firmware is:
Agent version:
2.1.8.9
APP Database version:
1.3.1
